how to get count of occurrences using Infotable API
AP_10343008
While taking distinct for any column in infotable, is it possible to get count of occurrences for each value along with distinct output?
You can use aggrgate for such use case,
Example:
2 REPLIES 2
Example:
Iam passing all the columns of datashape to aggregate service using for loop.
After aggregation, i couldnt get value from output infotable if i use
let value = infotable[i]."COUNT_"+FielName[i];
how to get these values?
