How to send the particular column value of selected row of a grid in Mashup1 to Mashup2 label?
Please help me achieve this.
Shalini V.
Hi @svisveswaraiya.
Without knowing more about your use case, take a look at these links from the Help Center to see if these may help:
Keep in mind that the session parameters are stored in memory, so storing a single column value should be ok but storing entire infotable properties could lead to performance issues.
--Sharon
Hi @svisveswaraiya.
--Sharon
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
