how to give selected row values to another mashup
svisveswaraiya
How to send the particular column value of  selected row of a grid in Mashup1 to Mashup2 label?
Please help me achieve this.
Shalini V.
slangley
(To:svisveswaraiya)
Hi @svisveswaraiya.
Without knowing more about your use case, take a look at these links from the Help Center to see if these may help:
Configure Mashup Parameters
Session Parameters
Keep in mind that the session parameters are stored in memory, so storing a single column value should be ok but storing entire infotable properties could lead to performance issues.
Regards.
--Sharon
slangley
(To:svisveswaraiya)
Hi @svisveswaraiya.
Session Parameters
Regards.
--Sharon
slangley
(To:slangley)
Hi @svisveswaraiya
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
