Please try this link, validator widget would be a perfect solution for you: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS250781&lang=en_US
What widget are you using as an image output?
Here is some more information on the Expression widget (requires support login): https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS233996&lang=en_US
and the Validator widget https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS250781&lang=en_US
Thanks for you reply, sent links are not working.
Please find below screen shot I have to show/hide image-473 based on value I get from service 1 or 0.
if 1 show, if 0 hide like that
Think of ValueDisplay widget which can show Images and has StateBased formatting
