how to merge 4 projects together
MM_9023322
Hi all,
I am trying to merge my 4 projects which have almost the same properties. From a single dashboard only, I must be able to access the different things linked with the different projects. What is the best way to do so?
Thank you
Hello @MM_9023322 ,
In your query, you have mentioned almost same properties. I am not able to understand the reference here.
Can you pls elaborate more ?
Bhawna
MM_9023322
(To:bchaudhary)
Hi @bchaudhary
What I mean is, there is 1 template under a project say Project-A which has Temperature, Speed, Level properties, and another project say Project-B has Temperature, Speed, and Volume properties in another template. Now, the current scenario is that I have created different projects, different templates, and different Mashups. But I want to know what is the best way to merge this project, templates, and mashup into single.
