how to switch mashup dynamic
csun-21
3-Visitor
I have 3 mashups,how to switch them dynamic every 30 seconds.and I don't want to use menu or master.thanks
4 REPLIES 4
posipova
20-Turquoise
(To:csun-21)
You could try to use Navigation widget and involve some custom services to implement the timer.
csun-21
3-Visitor
(To:csun-21)
ths,I use Navigation and atuo refresh wiget solved the problem.I add a navigtion widget link the mashup you want to jump,and use auto refresh widget set the time.
ankigupta
(To:csun-21)
Hi cyril sun​,
This can be done simply using Auto Refresh widget and Navigation widget. And bind the refresh event of Auto Refresh widget to navigate of navigation widget.
Auto Refresh widget: refresh interval as 30 seconds
navigation widget: target window as Replace
Set the visibility as false for both widgets.
Select the MashupName to which the Mashup should navigate after 30 seconds.
Repeat the steps for all 3 mashups.
I hope it helps.
thanks
