how to trace end to end location in composer by using googl map widget?
krotangan
i want to trace path so i have used google map extention from market place as per the guide and used Queryimplementingwithdata service but it was showing me static data but in this scenario i want to give manual input and trace the path between end points.
PaiChung
22-Sapphire I
(To:krotangan)
I believe you can use the Google GEO API services to get a set of coordinates, which then you would display.
May not be free.
