how to use openstreet map
SD_11980450
3-Newcomer
As per the original post
I am using ThingWorx 9.7.1-b346, I have imported above extension 'CommunitySupport_V1.0.2.zip' and added OpenStreetMap in mashup but while View Mashup, I am facing below error message: Unable to serialize JSONObject field - unsupported class : org.mozilla.javascript.ConsString.
I cannot view the map on view mashup. Please suggest.
Thanks.
Hello @SD_11980450 ,
I am not sure what you are trying to do with OpenStreets, The Extension I provided, is my hack at getting it to work.
I have had some success, also some failures in a testing environment.  If you create a Mashup and just add the OpenStreetMap widget, I believe you will get a map centered on London.
If you want to affect the information displayed you will need to create a data source. The data source can be a Service or property which is bound to the widget.  I took a quick look at ThingWorx 9.7.0 (closest version I have to your version) and It should display the initial map.
What data are you providing to the bindings?
If you can provide a Sample I will be happy to see if anything jumps out?
Pehowe
Hi @SD_11980450,
Anurag
