how to write service for scheduling program according to number of inputs in days,months,Years??
RM12
            I want to create program and schedule program according to duration dropdown with Days, Months and years .I want to calculate status according to time slot and display status before program start .If there is one program duration is 10 days and time slot is 7 to 8 AM, I want to schedule that program at daily basis
Please refer below attachment and suggest How do I write service  for scheduling program according to number of inputs in days, months, Years?? and How to refresh collection  with refreshing single parameter ??
Thanks in advance
amittal1
(To:RM12)
For this kind of requirements, you can use the mechanism of cron string/expressions https://docs.oracle.com/cd/E12058_01/doc/doc.1014/e12030/cron_expressions.htm  and then use thingworx 'Scheduler'.
If you see the Scheduler, you can configure it using cron expression.
Few more links for your reference -
https://www.ptc.com/en/support/article/CS210207
https://community.ptc.com/t5/ThingWorx-Developers/CRON-String-Format/td-p/621426
Maybe you have to write your own custom services which are able to take user inputs (from mashups) and then generate the cron string as output, which in-turn you can use to configure schedulers.
With your use case you might also need to create dynamic schedulers (create dynamic things and configure them)
I hope it helps and give you a pointer to start with.
Aditya
