Currently we are saving log data in valuestream via EMS with the setting below.
But, I though log data would be saved in value stream once every second, but seems three or four data entry are being saved every second. Which parts should I check??
I attached my microserver folder.
Yong June, are you logging multiple properties? Or is a single property logging duplicate entries?
It is our customer issue.
Multiple properties in Multiple Things are logging to same valuestream.
Multiple Things are similar to each other.
Our customer has one more issue~
refer to is there valuestream limitation?
it is critical issue~~ please help us...~~
Regards~~
