1. I created 2 properties in GlobalSessionProperties ThingShape.
2. From Thingworx composer, I go to CurrentSessionInfo Resource.
3. I select the service 'GetGlobalSessionValues' and execute it. It displays the 2 properties and their default values.
4. Next I select 'SetGlobalSessionStringValue' and execute it with one of the properties created in step 1 giving a different value. It successfully executes.
5. I select the service 'GetGlobalSessionValues' and execute it. It displays the updated properties.
Now I go into my Authenticator extension and execute the same steps from 2 - 4, it throws "java.lang.Exception: Invalid Global Session Parameter [null]" at step 4. Here are the details:
Step 2) Resource sessionInfo = (Resource) EntityUtilities.findEntity("CurrentSessionInfo", ThingworxRelationshipTypes.Resource);
Step 3) InfoTable sessionShape = sessionInfo.processServiceRequest("GetGlobalSessionValues", null);
printInfoTable(sessionShape); // Convenience method to print ValueCollection.
This does not print the 2 properties I create.
Step 4) Set the value
ValueCollection params = new ValueCollection();
params.SetStringValue("Property1", value);
sessionInfo.processServiceRequest("SetGlobalSessionStringValue", params);
The above line throws "java.lang.Exception: Invalid Global Session Parameter [null]".
Any pointers appreciated.
Pavan
The exception is happening because the processServiceRequest call was not invoked in the user's context. When we set the user's context and executed it there was not exception.
However the value is not stored and it is not being returned in GetGlobalSessionValues - I'll raise a different post for this.
Hi Pavan,
Do you see any different behavior trying the following?
For Step 2, try using this line instead:
SessionInfo sessionInfo= (SessionInfo) EntityUtilities.findEntity("CurrentSessionInfo", ThingworxRelationshipTypes.Resource);
Rob
Thanks Rob for the response. I tried that and still it throws the same exception.
