Thingworx 9.1.0
I have placed a label on a panel.The label can contain any number of characters.If the space gets exhausted then the information on the label is cut..Is it possible to get a scroll bar for label widget to show huge information or shall I use any other widget?
You probably need to not use the panel which may have made the area static.
A text area can be used but might look pretty ugly.
I had to limit the space..Can I place text area widget on a a panel?
Yes you can.
