Hi everyone,
I am using 8.5 and instead of of tab i want to use left column for choice(panel) . Example i want to make a 4 different pages and i want to have list of choices in left column. is there is any document or tips i can follow.
below is the example-
Yes. You need to use a tree widget to get the look you're after.
Which product is this?
Hi @nupur.
If the response provided by @wposner-2 resolved your issue, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
