HI team,
Can I have a multiple y-axis line in the line chart?
If it is possible Let me know how to achieve it.
Sharing the image how exactly I want to plot the multiple lines.
Hi @MK_9986318 ,
If you are using ThingWorx Platform 9.2.0" -> Widget Enhancements --> Chart widgets under the Themable category are now enhanced with the following features: ---> "Reference lines—Added support for horizontal and vertical reference lines on charts. You can use widget properties and bindings to add and configure the value, label, and orientation of each reference line on a chart."
Also I am attaching the URL for further reference:
Introduction to line chart widget extension
Kindly respond if you need further help.
Regards
Bhawna
Hi @MK_9986318 ,
Regards
Bhawna
There already is such function
