I'm trying to pass the name of "TrackerThing" to a service on a "CarThing" to bind the location property of the tracker to the car.
var params = {
propertyName: "location" /* STRING /,<br> sourceThingName: trackerName / STRING /,<br> sourcePropertyName: "location" / STRING */
me.SetLocalPropertyBinding(params);
The service runs with no effect. In the app log I see this error: "Invalid service name: GetRemoteMetadata"
I can perform this action manually.
Hi David,
I've created a case (#12119975) in our PTC eSupport Portal for this issue and you should have received an email with instructions for viewing it.
Adam
Sorry, I have the same issue with that function.
I have this code
var thingName = "DS-TH_prova";
var remThingName = "DS-RemTH_prova";
var paramsTH = {
thingTemplateName: 'DeviceSimulatorTemplate',
tags: tags
Resources["EntityServices"].CreateThing(paramsTH);
var paramsRemTH = {
thingTemplateName: 'DeviceSimulatorRemoteTemplate',
tags: tags
Resources["EntityServices"].CreateThing(paramsRemTH);
var props = {
propertyName: 'PropNum_4', //<<<<Property in Remote thing
sourceThingName: thingName,
sourcePropertyName: 'Temperature' //<<Property in thing
Things[remThingName].SetLocalPropertyBinding(props);
but it won't work.
Did you solve it a the end?
