Hi everyone,
I'm unable to connect my local oracle db in thingworx platform.Please find the attachment of connection string for connection.Could please anyone help me out on this...
Hi @Surekha,
Please validate the below points:
If you still face issue please share your error screenshot also. Also let us know to which version of oracle database you are making connection.
Himanshu
Hi @Surekha,
It seems to be an issue in the configuration. Can you please provide the configuration as below and validate :
JDBC Driver Class Name : oracle.jdbc.OracleDriver
JDBC Connection String : jdbc:oracle:thin:@localhost:1521:orcl
connectionValidationString : SELECT sysdate FROM dual
You need to change the localhost and orcl as per IP and SID of your oracle database.
Himanshu
Hi @hchanana,
Thank you for your response.I made changes which you have mentioned,but still it doesn't working.
Hi @Surekha,
Himanshu
Hi @hchanana,
We have connected to oracle server and changed configuration.Oralce configuration is connected but service is not invoked.
Hi @Surekha,
Can you please share screenshot of General Information and Configuration tab of your thing.
Himanshu
Hi @hchanana,
Please find the attachments of General Information,Properties and Configuration tab.
Hi @Surekha ,
Can you please confirm if you are still facing the connectivity issue. I have seen you opened support case related to this and solution was provided over the case.
Himanshu
Hi @hchanana ,
Oracle connectivity issue is cleared by using RDBMS Connectors.
Thanks & Regards,
Surekha N.
Hi @Surekha ,
Can you please mark the appropriate response as Accepted Solution, for the benefit of others who may have the same question.
Himanshu
