message: Invalid service name: GetRemoteMetadata
aagrawal-31
I have created Remote Thing "RemoteVendingMachines" and added all the properties. Then I had created Thing VM-TR1 and
  1. Click the  Manage Bindings button.
  2. Select RemoteVendingMachines
  3. Drag Prop_Equipment1Hum to CurrentHumidity
  4. Drag Prop_Equipment1Temp to CurrentTemperature
  5. Click the  Done button
  6. Click the  Save button
Result: Remote Thing value is not coming in CurrentHumidity and CurrentTemperature properties.
In Application log getting below Error:
[context: com.thingworx.webservices.context.HttpExecutionContext@35edcc9a][message: Invalid service name: GetRemoteMetadata]
I have verified services of Remote Thing "RemoteVendingMachines", GetRemoteMetadata service is present under
  • RemoteMetadataBrowsing
Note: Thingworx 7.4
Please suggest.
Thanks in Advance
4 REPLIES 4
supandey
(To:aagrawal-31)
Abhishek, I'm verifying this currently could be an issue with ThingWorx 7.4
supandey
(To:aagrawal-31)
Abhishek, I reproduced this issue and have filed a Jira ticket on this you can check this article for more detail https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS261320&lang=en_US
Hi Sushant, I am facing the same issue on 7.4. Any solution found until now?
supandey
(To:kgurunath)
Hi Konka, this is an issue with 7.4.0 I already have Jira filed for this with R&D. Will update this thread as soon as this is fixed. In the meantime you might want to use one of the 7.3.X versions.
