multiple DynamicSchedulerThing, but through single services .how to implement on multiple scheduler
Hariharasuthan
dear expert
I created multiple DynamicSchedulerThing, but through single services. How to implement on multiple dynamic schedulers? i need java script code for above
Hi @Hariharasuthan
Please follow the below steps :
Step 1: Create a new Scheduler ThingTemplate say 'MyCustomScheduler' from the default Scheduler Template
Step 2: Create a Subscription in ThingTemplate which you created in Step 1
Step 3: Subscription Event should be SchedulerEvent and put your custom email code from Project YYYY
Step 4: Now create a new scheduler Thing say 'scheduler 1' from Template 'MyCustomScheduler'
So whenever an event is triggered it will execute the code from Project YYYY
/VR
10 REPLIES 10
Could you explain the scenario with more detail? I cannot follow what you did or try to do, sorry.
step1:
scheduler 1 (weekly report) user 1
scheduler 2 (daily report) user 2
scheduler 3 (one hour report) user 3
scheduler 4 (monthly report) upto scheduler  N  (CRON ) values
i have  multiple  scheduler created in project xxxx
step2:
i have my own service (email sent ) created in project yyy
step 3:
 integrated to the step1 and step2 , regarding.
multiple scheduler user applying through via the email service. this type need code how to config please share me
thanks And Regards
Hariharasuthan
Hi @Hariharasuthan
Could you please elaborate on your case with some example
/VR
step1:
step2:
step 3:
thanks And Regards
Hariharasuthan
Hi @Hariharasuthan
/VR
hi @Velkumar
your share steps follow and implement but some problem and some doubt came here
1.Error(
Output
 Thing [Scheduler_Dynamic_CRON139l] is not enabled)
2.doubt
MyCustomScheduler
in this thing template and also some cron value but new scheduler 1 thing in this different cron value how is it,
Hi @Hariharasuthan
1. Is Scheduler_Dynamic_CRON139l created through service? if so enable it through service after the creation.
2. You don't need to worry about CRON String in Thing Template. The event will be triggered based on individual Thing CRON string
/VR
Hi @Velkumar
  previously shared information very useful thanks, multiple DynamicSchedulerThing, but through dynamic  services .how to implement on multiple scheduler
step1:
step2:
i have my own service (email sent ) but dynamic  created in project yyy
emailServices1 (To address different from address different subject different)
emailServices2(To address different from address different subject different)
emailServices3(To address different from address different subject different)
emailServices N (To address different from address different subject different)
step 3:
scheduler 1 (weekly report) user 1 --->emailServices1 (To address different from address different subject different)
scheduler 2 (daily report) user 2--->emailServices2 (To address different from address different subject different)
scheduler N (monthly report) up to scheduler  N  (CRON ) values  --->emailServicesN (To address different from address different subject different)
this code requirement  steps need to be please help me .
step 4:
var params = {
name:"Scheduler_Dynamic_CRON139ol" /* STRING */,
description: "DEMO Scheduler With CRON dynamically set" /* STRING */,
thingTemplateName:"MyCustomScheduler" /* THINGTEMPLATENAME */,
projectName:"MailserverGoogle" /* PROJECTNAME */,
runAsUser:"Hariharasuthan",
schedule:"0 0/1 * * * ?"
result = 'thing doesnt exist';
let thingName = params.name;
if (Things[thingName])
//Things[thingName].Enable();
result = 'thing exist';
Things[thingName].EnableThing();
Things[thingName].RestartThing();
logger.warn("thing exist "+thingName);
else
result="new one";
Resources["EntityServices"].CreateThing(params);
logger.warn("Thing Created: "+thingName);
var settings = Things[thingName].GetConfigurationTable({
tableName: "Settings" /* STRING */
/** UPDATE SETTINGS **/
settings.runAsUser = params.runAsUser;
//settings.schedule = "0 0/5 * * * ?";
settings.schedule=params.schedule;
Things[thingName].SetConfigurationTable({
configurationTable: settings /* INFOTABLE */,
persistent: true /* BOOLEAN {"defaultValue":true} */,
//Things[thingName].Enabled();
logger.warn("Thing Setting Update "+thingName);
// Things[thingName].Enabled();
THIS CODE CREATED  dynamic thingscheduler BUT  SERVICES  how add through SAME  ? thingscheduler in Dynamic process ?
thanks And Regards
Hariharasuthan
So how from & to email address varies? Do you have any criteria based on that you will be selecting from & to address ?
i have Cerita from thingworx services , i declare to email address .
E-mail services (to ,from, address  this value from database  sql server )
for example                         e-mail services
scheduler 1                     service1 -- to: hari@gmail.com   from :vel@gmail.com
scheduler 2                   service2 -- to: ram@gmail   from : kumar@gmail.com
scheduler 3                     service3-- to: mmm@gmail.com   from : nnn@gmail.com
scheduler 4                 service4 -- to: sss@gmail   from : sss@gmail.com
for this code email services in this filed was  various
Things["Mailserver_google"].SendMessageWithAttachment({
cc: "hari@gmail.com" /* STRING */,
path: "52.xlsx" /* STRING */,
bcc: undefined /* STRING */,
subject: "me test Report one mintues " /* STRING */,
fileRepository:"SystemRepository" /* THINGNAME */,
attachmentName:"52.xlsx" /* STRING */,
mimeType:"application/vnd.openxmlformats-officedocument.spreadsheetml.sheet" /* STRING */,
to: "testthingsworx@gmail.com" /* STRING */,
body: "Report At"/* HTML */
