I Created one organization and added user group into the same. and gave access to one of the my project but still i am not getting that project runtime. All the style and mashup is missing only the mashup which I gave it as home mashup for that organization is visible. but also all style definition is missing over there.
Thanks in advance
That's a great thought for improvement though (albeit very complicated to accomplish) but giving access to a project does not mean the entities in the project inherit those permissions.
To be honest the way permissions work, it is impossible to make that work.
So as was mentioned you have to apply permissions to each entity individually, there are some bulk options in Thingworx 8.3 I believe.
You should add permissions for Runtime to your group for templates, styles, services, etc.
Thank you,
Raluca Edu
