parseDate giving "invalid format" error
oaslan
I have two date values in String format like "2024-07-25 19:41:27.0000000 +00:00"
I want to calculate the time difference in between so I want to change them to date format. so used the code below but it gives me the invalid format error. Parsing neglects the year:
let StartDate = "2024-07-25 19:41:27.0000000 +00:00"
let sdf = "yyyyMMddHHmmsszzz";
result = parseDate(StartDate,sdf);
Invalid format: "2024-07-25 19:41:27.0000000 +00:00" is malformed at "-07-25 19:41:27.0000000 +00:00"
I even tried the slice the string, but I got the same error:
let ShortStartDate = StartDate.slice(0,19)
result = parseDate(ShortStartDate,sdf);
Invalid format: "2024-07-25 19:41:27" is malformed at "-07-25 19:41:27"
Arun_C
(To:oaslan)
HI @oaslan ,
Kindly find the below attached date conversion code which working for me.
let StartDate = "2024-07-25 19:41:27.0000000 +00:00";
let ShortStartDate = StartDate.slice(0,19);
///**// DateTime Format ///**///
let sdf = "yyyy-MM-dd HH:mm:ss";
Thanks & Regards,
Arun C
3 REPLIES 3
Arun_C
(To:oaslan)
HI @oaslan ,
Thanks & Regards,
Arun C
oaslan
(To:Arun_C)
Dear Arun,
It worked, thank you for your support. It seems the sdf format should be properly defined.
VladimirRosu
(To:oaslan)
It's probably good to know that the parseDate uses the format from the Joda library and examples can be seen here:
https://www.joda.org/joda-time/apidocs/org/joda/time/format/DateTimeFormat.html
Note there are a few articles related to parseDate in the support.ptc.com, and specifically this one explains how to use it and links to the site above.
