parseDate works in service but does not work in subscription
Willie
The parseDate function works when I run it in a service for testing purposes, but it does not work when I try to use it in a subscription that calls a service that uses the parseDate function.
Please see below:
Working example: Converts PST time to JST time
Not working: Service called by subscription
Error: "Invalid format"
For reference:
https://www.ptc.com/en/support/article/CS219448
https://www.joda.org/joda-time/apidocs/org/joda/time/format/DateTimeFormat.html
I found the error....
It seems that I was using "eventData" instead of "eventData.newValue.value" as the input in the subscription....
The subscription is triggered based on DataChange.
PaiChung
22-Sapphire I
(To:Willie)
It seems to want to 'pass on' time from epoch?
not sure why it works in one and not the other, is there any basetype differences?
Basetypes of both services:
Input: string
Output: TimeStamp
slangley
(To:Willie)
Hi @Willie.
Which version of ThingWorx are you running? We tested under 8.5.3 and received an unexpected result.  We'll probably need to open an internal case for this.
--Sharon
I am using thingworx v8.4.5
