The legend text of pie chart is getting trimmed. Is there a way to display whole text?
Thanks in advance,
Shalini V.
Hi @svisveswaraiya ,
I have tested it and the only way that worked for me to show the full text of the legend was to select LegendOrientation as Vertical instead of Horizontal.
Hope it helps,
Hope it helps,
Hi @Ciprian-Traian ,
Thanks for your swift response.
The legend orientation is already set in vertical. But still this occurs.
Hello @svisveswaraiya
Can you please help me with version of your thingworx?
I tried it on 8.5.7 and its working fine for me.
Om DUkiya
If you are still facing the issue than please share the sample entities to understand it better.
Om DUkiya
Hi @odukiya ,
I was able to figure out the issue and fixed it. I just made the Label format blank and then it worked.
Thanks.
