after launching thingworx web application, the composer is showing sever error
Since composer wants to launch it seems ThingWorx is running, you can go to the ThingworxStorage/logs folder and look at the application log for hopefully more information.
Also you can check the tomcat/logs/catalina logs
thank you sir, is it Actually for web application or locally installed one ?
Hi @VV_10007690 , Can you please share the logs from ThingWorx storage folder and Tomcat logs also.
