question concerning SetConfigurationTable
kyetzer
I have a Thing that is based on the EdgeEnhanced Thing Template.  I would like to be able to change the configuration property:  "Channel override" from a service.   I would assume that you could use SetConfigurationTable or SetConfigurationTableRows.  However I cannot figure out what the name of the table is.  Do configuration tables have default names?
3 REPLIES 3
kyetzer
(To:kyetzer)
I should mention that the version of Thingworx used here is 4.0.  This version did not have the service:  GetConfugrationTables.   So is there any other way one could use to determine the names of the configuration tables used
PaiChung
22-Sapphire I
(To:kyetzer)
Easiest way is to use the REST API do <server>/Things/NameOfThing?Accept=text/xml
Then search for configuration there may be several configuration tables depending on the type of Thing.
kyetzer
(To:PaiChung)
Thanks Pai
