How to "Add captcha" in Organization login page of thingworx
Hello @AP_9587236
Unfortunately, this is Currently NOT part of ThingWorx functionality.
pls check the following link:
https://www.ptc.com/en/support/article/cs224493
Regards
Bhawna
This article says that "It applies to - ThingWorx Platform 5.4 to 8.5 SP1". So Adding captcha is possible in Thingworx 9.2 version ?
Hi @AP_9587236
I have checked about captcha in 9.2 and It is not out of the box. You can put an enhancement request in/post an "idea" on the community board or implement a custom authentication solution.
pls chk the following artile for custom authentication:
https://www.ptc.com/en/support/article/cs244163
Regards
Bhawna
Any custom authenticator extension is available in marketplace ?
Hello @AP_9587236 ,
pls check the following articles:
https://www.ptc.com/en/support/article/CS244163
https://community.ptc.com/t5/ThingWorx-Developers/Custom-Authenticator-Example/td-p/522456
https://developer.thingworx.com/resources/guides/create-authentication-extension
Let me know if you need anything further.
Regards
Bhawna
