Hello everyone,
I am trying to import an extension, and I keep getting the error I wrote down in the Subject:
"Entity Import Not Supported for File Type: .zip"
this happens with any extension, also the one build in this tutorial. The only thing I have done differently is the Gradle build, which I carried out via Command Prompt, but the error shows up also if I use the pre-built .zip file in the tutorial files.
I am using a 30-day cloud trial now, so I wonder if this could be a limitation of the trial.
Thanks and best regards!
Are you importing this specifically as extension import or just "file import"? Please make sure to use "Extension Import" .
Best Wishes!
Teresa
Best Wishes!
Teresa
Hi @jman87 ,
This definitely was the issue, the thing being that I got confused by the second window, erroneously selecting "From File" because I thought it meant "Import extension from file".
Thanks for the help,
Federico
Hi @Rocket_Max,
Thanks for the answer. I'm going to accept @jman87's answer just because it came first chronologically.
Federico
