I've had to switch from the Neo4J ThingWorx to using the PostgreSQL version of ThingWorx. I de-installed the current version, deleted ThingWorxStorage and ThingWorxStoragebackup and installed the PostgreSQL version.
When I started ThingWorx again I got the message "Failure to return license click check".
I read this document, and I
What might be causing this problem?
It turns out this was due to a misconfigured PostgreSQL database connection.
If you haven't done already, please open a case with support.ptc.com
Thanks!
As Pai suggested, please do open a support case. On a side note, does this error occur on all browsers or specific ones? If you have not tried yet, can you retry on both Chrome and Firefox?
