when i Open Application log in monitoring am getting an error called "Internal server error".
I have mentioned the correct code in tomcat->java option.Then as well am getting that error.
-Duser.timezone=UTC
-Dserver -Dd64
-XX:+UseG1GC
-Dfile.encoding=UTF-8
Hi @DS_10580803
Have you checked this article - Article - CS347487 - Internal Server Error when trying to access Application Log from Thingworx Composer
/VR
Hi @DS_10580803
/VR
Hi @DS_10580803,
It appears that a response to this post answers your question. For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
