raspberry pi connect
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
I am using demo version of Thingworx to connect my Raspberry pi to view OBD diagnostics. I successfully connected pi few times and downloaded the agent into it. When ever I try to connect, it always prompt error "Yoo cannot connect more tahn 5 device. please delete the device and try again"
I am not sure either ThingWorx keep record of pi MAC address or store IP address to check multiple connectivity.
I did try with another pi with different MAC address, showing same error.
Please help to out to connect my device with platform.
Thanks ...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Muhammad, did you successively try to connect? You might have multiple active sessions.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
No, I reinstall my raspberry pi OS and relevant software's but still I am getting same error.. "You cannot have more than 5 devices. Please delete a device and try again!"
I search this specific error in existing community but no relevant information is available
Can you please suggest me possible reasons and way to remove this error ?
Your prompt response is highly appreciated.
Asif
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Have you tried deleting your existing Remote Things on the platform and then creating a new one to connect?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I tried but failed to navigate forward because when I try to connect APP OR Device tutorial, this error appears...and I cannot proceed forward ...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Muhammad, by connect, I meant logging into your ThingWorx platform/ server and then deleting your Remote Things.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi Support Team,
Thanks for your support. I refresh everything (Pi OS/Software) and follow the example for Pi at followoing link:
I am remotely connected to pi using putty at my desktop PC. AT my desktop, platform shows me successful connectivity to pi but unable to show/get "LightSTatus" and "LightLocation" property values on platform.
Do I need some special modifications in source file index.js files (example-3) OR Do i need to connect Pi directly. (Not connecting remotely using Desktop PC) ?
Looking forward your feedback.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Are there any error messages on the logs? Did you remotely bind those properties?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi Aanjan,
Thanks for all your support and guidance to demonstrate GPS location and Light Value on Mashups and ultimately values are on platform. Now the problems are:
1: When I navigate to next page for "enhance", link always fail to demonstrate "This site can’t be reached". It seems like trial that demo account users cannot access more pages. AM I correct ?
2. Currently, using example-3, containing node.js source code. I want to map real values instead of dummy values. In fact I want to get real values of GPS and OBD-II connector from car and map them on agent so that real values should be displayed.
Asif
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Muhammad, I would need to check on first section regarding limitations. Where does it navigate or gets redirected to? For that second point, since you are using a simulator to generate values, that would be your actual limitation. We have SDKs and EMS-es that you can use to leverage your connection(s).
