restart of the server
Test_user
Does restart of the Thingworx server is required each time when make changes in the extension(developed using java) and remport it to the Thingworx server?
please help me over here.
Yes, that is mandatory.
The platform informs you of this with a message after an Extension import.
2 REPLIES 2
jensc
(To:Test_user)
That was my experience when I played around with building my own extensions.
However I do not remember if it was only when I changed the version number or not.
Since I didn't have access to restart the server myself, I just renamed the extension each time I did a change.
Jens
