runtime mashup in mobile
svisveswaraiya
How can I access the runtime mashup in my mobile.
I have connected both the laptop and mobile in same network and am using the ip address instead of localhost.
But still it shows me an error : The web page is not available.
How can I resolve this?
V SHALINI.
6 REPLIES 6
Hello.
A few things to check:
Can you access this with another computer on the same network (not a mobile device)?
Is there any firewall configured on the host system that might be blocking access?
Are you using the correct port to access (maybe not port 80)?
-- Craig A.
Hi CRArko,
I tried it in another computer with same network but it doesnt work.
When I checked the ip address it shows different Ip for two computers with same network.
The port number is right.
Now, what can I do to resolve this issue?
Is there a firewall running on the ThingWorx host computer/VM? If so, can it be temporarily disabled?
If you just try connecting to tomcat. but not the ThingWorx Composer, does that work?
-- Craig A.
I just checked the Firewall is already disabled and the tomcat is also not accessible.
V Shalini.
But everything works properly when connecting from the local machine to the local machine, is that right?
Can you ping the hosting system from a remote device?
Thank you,
-- Craig A.
slangley
(To:CRArko)
Hi @svisveswaraiya
Have you found a solution to your issue?  If so, we would love for you to post it here and mark it as the Accepted Solution for the benefit of others with the same issue.
--Sharon
