I have created Azure SQL srever and created thingworx database. I am trying to create schemas on thingworx database using script which provided by thingworx installation. Below are errors while running the schema setup script. I am using thingworx 8.5.11 Thingworx version.
Setting up ThingWorx schema and creating user twadmin in thingworx...
Password: sqlcmd : The term 'sqlcmd' is not recognized as the name of a cmdlet, function, script file, or operable progr
am.
Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
At C:\Softwares\MED-61280-CD-085_SP11_ThingWorx-Platform-Azuresql-8-5-11\install\thingworxAzureSingleInstanceSchemaSetu
p.ps1:84 char:1
+ sqlcmd -S $server\\$serverinstance,$port -U $sqlserverloginname -d $database -i ...
+ CategoryInfo : ObjectNotFound: (sqlcmd:String) [], CommandNotFoundException
+ FullyQualifiedErrorId : CommandNotFoundException
cat : Cannot find path 'C:\Softwares\MED-61280-CD-085_SP11_ThingWorx-Platform-Azuresql-8-5-11\install\tempLogFile.log'
because it does not exist.
p.ps1:41 char:19
+ $tempContents = cat tempLogFile.log | Select-String -NotMatch "Password:"
+ CategoryInfo : ObjectNotFound: (C:\Softwares\ME...tempLogFile.log:String) [Get-Content], ItemNotFoundEx
ception
+ FullyQualifiedErrorId : PathNotFound,Microsoft.PowerShell.Commands.GetContentCommand
rm : Cannot find path 'C:\Softwares\MED-61280-CD-085_SP11_ThingWorx-Platform-Azuresql-8-5-11\install\tempLogFile.log'
p.ps1:45 char:3
+ rm tempLogFile.log
+ CategoryInfo : ObjectNotFound: (C:\Softwares\ME...tempLogFile.log:String) [Remove-Item], ItemNotFoundEx
ception
+ FullyQualifiedErrorId : PathNotFound,Microsoft.PowerShell.Commands.RemoveItemCommand
Setting up model schema...
am.
p.ps1:94 char:3.............................................
Vidyullatha
Hello @vi1
So the error related to sqlcmd here shows that you have not installed A valid Microsoft SQL client (sqlcmd) and is not available in the PATH environment variable .But this is a prerequisite for microsoft SQL server.
Have you tried to install the database to SQL server here and trying to migrate to azure later? If yes this is something you are missing here.
Apart from it for Azure SQL you need to setup azure CLI where you can run your DB and schema setup scripts.
Please feel free to revert in case it doesn't resolve your query.
Om Dukiya
Hello @vi1
Om Dukiya
Thank you for response.
I will reinstall SSMS again and add the path in environmental variables.
I have installed azure CLI and used windows power shell and connected to az login, run the script.
Latha
Hello @vi1
So if the issue has been resolved and you feel your question has been answered, please mark the appropriate solution as accepted for benefit of others. If you have further question please feel free to revert.
Om Dukiya
