search elements in infotable/streams
K_Bairagi
How to Search respective values/DATA of an infotable from any of its specfic row element?
Thanks & Regards
K Bairagi
K_Bairagi
(To:PaiChung)
I have tried with QueryStreamEntriesWithData but didn't work for me..
can you give an example by making use of a datashape, streams, infotable?
example with coding will help...!
Thanks & Regards
K Bairagi
9 REPLIES 9
PaiChung
22-Sapphire I
(To:K_Bairagi)
Streams and DataTables provide Query as well as DataTables provide Find
once the data is in an infotable, you again have Query but also Search
K_Bairagi
(To:PaiChung)
Can you name the function in javascript which I can use in my coding?
Thanks & Regards
K Bairagi
PaiChung
22-Sapphire I
(To:K_Bairagi)
there is an infotable snippet for Query
Resources["InfoTableFunctions"].Query
within the infotable object you can use find
http://support.ptc.com/help/thingworx_hc/javadoc/com/thingworx/types/InfoTable.html?wwreverbsearch_action=search_display_link&wwreverbsearch_highlightRequireWhitespace=false&wwreverbsearch_query=search
DataTables and Streams have built in services, you can see them when you browse through the Entity browser etc.
K_Bairagi
(To:PaiChung)
How to query any specific field of the stream with multiple fields?
Please name the function.
Thanks & Regards
K Bairagi
PaiChung
22-Sapphire I
(To:K_Bairagi)
K_Bairagi
(To:PaiChung)
Thanks & Regards
K Bairagi
PaiChung
22-Sapphire I
(To:K_Bairagi)
Hello @K_Bairagi
Can you tell me what exactly you want to do ?
Velkumar R
