searchExpression syntax
DenisSimonneau
6-Contributor
Is anyone know what is the searchExpression syntax for the SearchDataTableEntries in a datatable
Thanks for your help
Denis
4 REPLIES 4
smanley
(To:DenisSimonneau)
Are you referring to the query for DataTables code snippet?
No, I'm refering to the searchExpression input parameter we have in the service SearchDataTableEntries for a datatable
smanley
(To:DenisSimonneau)
Is there a particular reason you prefer using the SearchDataTableEntries service rather than using a Query for the dataTables? We recommend using a query to search through dataTables.
No, there is no reasons.
I can also use Query but I was wondering if it could be easier to use searchExpression but for that I need to know what is the Syntax
