Is anyone know what is the searchExpression syntax for the SearchDataTableEntries in a datatable
Thanks for your help
Denis
Are you referring to the query for DataTables code snippet?
No, I'm refering to the searchExpression input parameter we have in the service SearchDataTableEntries for a datatable
Is there a particular reason you prefer using the SearchDataTableEntries service rather than using a Query for the dataTables? We recommend using a query to search through dataTables.
No, there is no reasons.
I can also use Query but I was wondering if it could be easier to use searchExpression but for that I need to know what is the Syntax
