selected row remove on infotable
I wanna remove selected row  on infotable.
The delete query inputs the info table and query. so I made Service to bring property into the infotable.
And I used eqfilter was used to select the value in the infotable.
ex) getService : A service that brings property into the infotable.
      primary_field : A field I wanna delete
      1 : selected row on primary_field value
var tray = me.getSevice({
thingName: thingName
var traydelete = {
fieldName: "primary_field " ,
isCaseSensitive: undefined,
t: tray,
value: "1"
var td = Resources["InfoTableFunctions"].EQFilter(traydelete);
var params = {
t: tray, /* infotable */
query: traydelete /* query */
var result = Resources["InfoTableFunctions"].DeleteQuery(params);
but I get Output : Wrapped java.lang.NullPointerException
Infotable, there is a "primary_field" and values "1"
Somebody help me! Or tell me how to delete another one.
Would it be ok, tell me how to update that selected row.
Thank you!
18-Opal
Hello @JackEom,
Try this:
tray.Delete({ primary_field: "1" });
Constantine
Didn't go through the entire code but there seems to be a typo(a missing 'r')
18-Opal
Hello @JackEom,
Try this:
Constantine
