thingWorx // Solution Framework can not execute GetBuildingBlocks List method
NicoGreffard
7-Bedrock
I am working on ThingWorx 9.4 and I try to use "Solution Framework" version 1.12.1 delivered by PTC, available on GitHub https://github.com/PTCInc/twx-solution-framework/releases.
I applied the procedure described on gitHub,  including all extensions dependencies installation (here is the list of BB installed).
When I open the Mashup PTC.SolutionFramework.Main_MU, the GetBuildingBlockList Method of Installed BuildBlocks fail with following alarms error :
=> "Thing [PTC.SolutionFramework.Manager] Service [GetBuildingBlockList] error at line [2.0] : TypeError: Impossible method  "{1}" de {0}"
and Warning
=> "No Manager was found for identifier [PTC.ComponentManagement.Manager]"
I did not found any post that my help us to solve  this issue.
Could you please help us to solve such issue  ?
The issue described in my previous post has been solved  by applying the following pre-requistes related to the Common Building Blocks installation :
"https://support.ptc.com/help/building_blocks/r1.1/en/index.html#page/bb/building_blocks/getting_started_with_building_blocks/deploying_building_blocks_using_ptc_software_downloads_page.html#"
After this step application, solution framework is able to List all Building Blocks available on the ThingWorx platform.
=> solution is ok
1 REPLY 1
=> solution is ok
