I did not found any post that my help us to solve this issue.
Could you please help us to solve such issue ?
The issue described in my previous post has been solved by applying the following pre-requistes related to the Common Building Blocks installation :
After this step application, solution framework is able to List all Building Blocks available on the ThingWorx platform.
=> solution is ok
=> solution is ok
