unable to fetch data table entries with a string primary key
adey-2
I have a data table with a string primary key. however, i store GUID in it. I am not able to fetch the data table entries in a service that takes the primary key's value as a parameter. I have something like this:
In one service:-
var guid = generateGUID();
            // log user request in DT
            var values1 = Things["UserRequests"].CreateValues();
            values1.Status = 0; // in progress
            values1.RequestID = guid; //GUID [Primary Key]
            values1.RetryCount = 0; //INTEGER
            values1.LoggedTime = new Date(); //DATETIME
            values1.VehicleID = vehicleID;
            var params1 = {
                sourceType: undefined,
                values: values1,
                source: undefined,
                tags: undefined
            Things["UserRequests"].AddDataTableEntries(params1);
In another service that takes the request id:-
var values = Things["UserRequests"].CreateValues();
values.RequestID = RequestID; //STRING [Primary Key]
var params = {
  maxItems: undefined /* NUMBER */,
  values: values /* INFOTABLE*/,
  query: undefined /* QUERY */,
  source: undefined /* STRING */,
  tags: undefined /* TAGS */
// result: INFOTABLE
var result = Things["UserRequests"].QueryDataTableEntries(params);
result.length returns 0
6 REPLIES 6
jkaczynski
(To:adey-2)
Hello Anuria Dey​,
If you want to get entry by key, there is a better solution. It assumes, that you have only one primary key, it won't work if you have more primary keys on the Data Table:
var params = {
     key: "GUID"
var result = Things["RequestDataTable"].GetDataTableEntryByKey(params);
However, your way also should work correctly. I just copied your code and if I invoke the second service and pass correct RequestID, it works.
After you invoke first service, is a new entry to DataTable added?
Hope it helps.
J.
Thanks Jakub for a prompt response!
I have tried this out as well.
The main problem i'm facing is that i pass the Request id i used to add a data table entry into another service, where i want to use it to fetch a particular entry from the table. what i observe is that maybe it does not detect the Request id as a string and hence does not fetch me any entry. When a hard code a guid like:
  1. var params = {
  2.      key: "<any guid>"
  3.
  4. var result = Things["RequestDataTable"].GetDataTableEntryByKey(params);
it works and fetches the corresponding entry but not in case of the variable which i am supposed to use.
Is there any way i can convert it to a string??
jkaczynski
(To:adey-2)
Hi Anuria Dey​,
It depends on what type of object you have in the variable. You can try to log your variable to the Script log and check if it is correct, so:
logger.warn("Request ID: " + RequestID + " is of a type: " + typeof RequestID);
Additionally, to make a string from a basic types, you can try to invoke a toString() method on the variable, e.g.:
var keyString = RequestID.toString();
Hope it helps. If so, you can concern to mark my previous or this answer as a Correct Answer for other users to refer.
J.
nkhose
(To:adey-2)
Extending on this .. we can also accomplish by adding a subcription on datatable and select event update or add , pass in the id parameter which is the primary key set of your datashape and script as like.. .
if(eventData.id)
Things['yourDataTable'].SecondServiceInvoke({Primary_Id:eventData.id});
So above subcription will always invoke whennever you add or update the datatable in this case you may set the event as ADD .
Also to note eventData.id will always return the newly generated primary key whatever you have set int or GUID
adey-2
(To:adey-2)
Sorry i forgot to mention that the second service where i am passing the request id(table's primary key) as parameter is an async service Seems like an issue with that. Also i am using ThingWorx 6.6 composer
ptc-6292103
(To:adey-2)
Basically, the first service starts a new transaction, and changes made by that transaction are not available to other threads (async services are new threads) until the transaction closes.
You are much better off switching to a subscription instead of an async service. The subscription will fire when the event happens (Add, Update, Delete, ect), which will be after the transaction closes.
