Hi
I created one model in thingworx analytics which have 0 lookbacksize and 5 lookahead and calling that model in thingworx service by executeJob() and trying get the 5 output data as there are 5 lookahead but unable to get the 5 output data. Can anyone help me to resolve this issue.
Hi @Ru
Here are some further information:
When you score records against a model with lookahead 5, it will output only one score result for t+5.
It does not output 5 results for t+1, t+2, t+3, t+4 and t+5
If you want to have output for t+1, t+2, t+3, t+4 and t+5, you need to create 5 models each with a different value of lookahead from 1 to 5.
I hope that clarifies the output you see
Hi @Ru
