using ImportSourceControlledEntities to import a single entity
cbaurand
11-Garnet
How can i use the ImportSourceControlledEntities  service to import a single entity: I guess i need to use the entityFilter parameter, but i'm not able to find the correct syntax:
   let entityFilter = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({
        infoTableName: "InfoTable",
        dataShapeName: "EntityDifference"
    entityFilter.AddRow({name: "myTemplateToImport", entityType:"ThingTemplate"});
    Resources["SourceControlFunctions"].ImportSourceControlledEntities({
         entityFilter: entityFilter,
         repositoryName: "SystemRepository",
         path: "src/twx-source"
Any help or example would be appreciate.
7 REPLIES 7
wcui
(To:cbaurand)
hi cbaurand
entityFilter is not necessary parameter. please refer to below sample code which I ran successfully on TW9.3.2 instance.
let params = {
entityFilter: undefined /* INFOTABLE {"dataShape":"EntityDifference"} */,
path: "/Things" /* STRING */,
useDefaultDataProvider: undefined /* BOOLEAN {"defaultValue":true} */,
withSubsystems: undefined /* BOOLEAN {"defaultValue":false} */,
overwritePropertyValues: undefined /* BOOLEAN {"defaultValue":true} */,
repositoryName: "RepThing" /* THINGNAME */
// no return
Resources["SourceControlFunctions"].ImportSourceControlledEntities(params);
cbaurand
11-Garnet
(To:wcui)
My intention was to import a single entity. Your response is irrelevant.
wcui
(To:cbaurand)
I attached a picture where I ran ImportSourceControlledEntities from composer. I defined entityFilter to only import thing with name "test2".
For your use case, you can define InfoTable with data shaple "EntityDifference", add a row to with entityType as "Thing" and name as target thing name.
I am also not sure about the syntax of the entityFilter, specifically the entityType, but I found in our support portal a case that suggests this works, even if you see in the log that they are processed.
If I would need a workaround now, I personally would move the entity I need to a temp folder, then process that folder via this service (without using entityFilter), then delete the folder at the end of the process.
Note: of course, if the case I shared does not apply, you should open a Technical Support case to get this function documented in a Support Article.
Actually, this case was found by Charlotte (ptc) and me a few weeks ago. Ii works, but the traces suggest that the filter doesn't work.
Thanks for your reply.
wcui
(To:cbaurand)
yes, below article also mentions that. Info Application log is output for every entity even with filtering.
https://www.ptc.com/en/support/article/cs370821
are we good to close this?
cbaurand
11-Garnet
(To:wcui)
yes
