using "new Date" function of javascript in my service is not providing me with the desired output
MD_10945249
I have this function which takes lastVisitTime of type string.
string date value is "2024-11-12 10:00:01"
result of code when compiled on js compiler
let dateFromString = new Date("date in string");
output ->
2024-11-12T10:00:01.000Z
 output type is
object
result of code when thingworx service is executed
output -> invalid date
output type is
object
 could someone help me with this I want to convert my date string to date.
Thanks in advance.
Rocko
(To:MD_10945249)
When you give a string to new Date(), it must be in  "YYYY-MM-DDTHH:mm:ss.sssZ" format.
See https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/Date#date_time_string_format
Try replacing the space with a T:
2024-11-12 10:00:01 -> 2024-11-12T10:00:01 -> new Date("2024-11-12T10:00:01");
Rocko
(To:MD_10945249)
MD_10945249
(To:Rocko)
Thank you @Rocko this does work.
Alternatively you can do this:
let date = parseDate("2024-11-12 10:00:01", "YYYY-MM-dd HH:mm:ss");
Vilia (my company) | GitHub | LinkedIn
