How Can we integrate with a mashup?
For value streams you can use QueryPropertyHistory service, it queries the value stream for logged property values, along with filter and sort criteria, and normalizes the data set to display results for a given time range. There are other services as well, you can refer this help center guide for details.
For streams you can use GetStreamData service to get all the data in the stream. Other services are mentioned in this guide.
Sachin Sharma
Hi @VS_10112707 ,
I am not able to understand the query. Can you please elaborate it more?
Regards
Bhawna
value stream and stream data storage what is the exact use case? and can we connect it with thingworx mashup builder?
Hi @VS_10112707 ,
To create the value stream, follow this link: https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx/Help/Composer/DataStorage/ValueStreams/CreatingaValueStream.html
To create stream data storage, follow this link:
Revert back if you need any further clarification
Regards
Bhawna
@bchaudhary thanks but my concern is can we use that in mashup to display data as we using infotable to show in mashup
Hi @VS_10112707 ,
Yes you can use that in mashup. You can call Query PropertyServices to get the data.
Regards
Bhawna
Sachin Sharma
