what is Expression widget and how it work ?
asingla
brue
(To:asingla)
The ThingWorx Documentation has a brief description, a video tutorial about how to use a simple expression, and descriptions of the properties. I've copied that content here:
Expression Widget
The Expression widget evaluates an expression and is invisible at run time.
View the following video tutorial for more information: How to Use an Expression Widget.
Note
Styles and common widget properties are not included in the table below.
checkbox
Property Name
Description
Base Type
Default Value
Bindable? (Y/N)
Localizable? (Y/N)
Expression
The expression to evaluate.
STRING
n/a
N
N
AutoEvaluate
Automatically evaluate the expression when the value of its inputs change.
BOOLEAN
False
N
N
FireOnFirstValue
A boolean value indicating whether the Changed Event should be fired when the Expression widget is supplied its first value.
BOOLEAN
False
N
N
DataChangeType
The type of data change that must occur to fire the Changed Event (Value, Always, or Never).
BOOLEAN
Value
N
N
Output
The output of the expression.
NUMBER
n/a
Y
N
OutputBaseType
The base type of the output (NOTHING, BOOLEAN, DATETIME, LOCATION, NUMBER, TAGS, or STRING).
STRING
NUMBER
N
N
Changed
Event. The Event fired by the Expression widget when its output is changed.
n/a
n/a
Y
N
Evaluate
Service. Evaluates the expression.
n/a
n/a
Y
N
Visible
Is the widget visible in runtime?
BOOLEAN
True
Y
N
asingla
(To:brue)
Thanks Brian.
