when Dropdown list holds values from Infotable created as Property in a Thing
VaibhavShinde
I have bound my Infotable data (created as property with only one Column) with Dropdown . i am getting values in dropdown but how can i take selected value as input to a Service?. my infotable property finds in getPropertyValues().
I believe this query is related to your previous query. This type of design is very straight forward but I believe there is something in your design which is not clear from your query description. One of the issue in your design can be are you trying to do a selected row from a nested infotable ? That basically means are you trying to select a property from an infotable which is under Selected Row(s) section of data panel ? I would like to tell you Selected Row(s) is itself an infotable and you can select property under this. But if you want to select a property which is under a property of type infotable which is again under the hood of Selected Row(s) it will not work this way. you will not be able to use selected row from nested infotables. You can see my simple mashup attached for reference.
If you have something else, then please elaborate more clearly.
Mukul Narang
Mukul Narang
Thanks for sharing Mashup snap . worked.
