where+groupby on infotable/datatable
vijay5
Hello Team,
I need to get count of specified values(where in sql) on a column groupby some other column from infotable.
Any help will be appreciated!!
raluca_edu
(To:vijay5)
Example for a Thing having a property INFOTABLE info1 (datasahape has fields : age, name, id)
Service (input: nothing, output: number ) that gets the number of persons under age 20:
var query = {
sorts:
[{ fieldName: "age",
isAscending: false
filters:
{ type: "AND",
filters:
type: "LT",
fieldName: "age",
value: 20
var resultTable = Resources['InfoTableFunctions'].Query({
t: me.info1/* INFOTABLE */,
query: query /* QUERY */
var result= resultTable.rows.length;
Hope it helps,
Raluca Edu
PaiChung
22-Sapphire I
(To:vijay5)
There is an InfoTable function called Aggregate that you can use
it has the Aggregate types of COUNT, AVERAGE, MIN, MAX, SUM
it also has grouping columns you can designate.
It will then produce a new table with your grouping columns and fields named SourceFieldName_COUNT
etc. based on what you want to aggregate
mgoel
(To:PaiChung)
@vijay5
Hope you are doing good. Could you please confirm if the issue has been resolved.
If yes, please mark the answer as accept as solution for the future reference. Thank you in advance.
Regards-Mohit Goel
