Hi ,
whenever try to transfer file from Thingworx to Remote SDK using COPY service in Filetransfer subsystem, we are getting "java.lang.Long cannot be cast to java.lang.Double"
these are the log we are getting :
2017-11-30 15:40:22.614 | INFO | NotifyDFTNQueue service - End | SuperUser | S.c.t.d.e.DSLScript | TWEventProcessor-8 | ||
2017-11-30 15:40:22.475 | INFO | File transfer completed event start | SuperUser | S.c.t.d.e.DSLScript | TWEventProcessor-8 | ||
2017-11-30 15:40:22.475 | INFO | File transfer Completed status ++++++++++++++++++++++++++++++++++false | SuperUser | S.c.t.d.e.DSLScript | TWEventProcessor-8 | ||
2017-11-30 15:40:22.475 | INFO | File transfer event message ++++++++++++++++++++++++++++++++++java.lang.Long cannot be cast to java.lang.Double | SuperUser | S.c.t.d.e.DSLScript | TWEventProcessor-8 | ||
2017-11-30 15:40:22.475 | INFO | File transfer event target file ++++++++++++++++++++++++++++++++++Sample.zip | SuperUser | S.c.t.d.e.DSLScript | TWEventProcessor-8 | ||
2017-11-30 15:40:22.475 | INFO | File transfer event source file for Uplink ++++++++++++++++++++++++++++++++++undefined | SuperUser | S.c.t.d.e.DSLScript | TWEventProcessor-8 | ||
2017-11-30 15:40:22.475 | INFO | Downlink File failed java.lang.Long cannot be cast to java.lang.Double | SuperUser | S.c.t.d.e.DSLScript | TWEventProcessor-8 | ||
2017-11-30 15:40:22.475 | INFO | NotifyDFTNQueue service - Start | SuperUser | S.c.t.d.e.DSLScript | TWEventProcessor-8 | ||
2017-11-30 15:40:22.185 | INFO | File transfer completed event start | SuperUser | S.c.t.d.e.DSLScript | TWEventProcessor-7 | ||
2017-11-30 15:40:22.185 | INFO | File transfer Completed status ++++++++++++++++++++++++++++++++++false | SuperUser | S.c.t.d.e.DSLScript | TWEventProcessor-7 | ||
2017-11-30 15:40:22.185 | INFO | File transfer event message ++++++++++++++++++++++++++++++++++Transfer request accepted | SuperUser | S.c.t.d.e.DSLScript | TWEventProcessor-7 | ||
2017-11-30 15:40:22.185 | INFO | File transfer event target file ++++++++++++++++++++++++++++++++++Sample.zip | SuperUser | S.c.t.d.e.DSLScript | TWEventProcessor-7 | ||
2017-11-30 15:40:22.185 | INFO | File transfer event source file for Uplink ++++++++++++++++++++++++++++++++++undefined | SuperUser | S.c.t.d.e.DSLScript | TWEventProcessor-7 |
Application LOG:
2017-11-30 14:41:34.981 | ERROR | [context: java.lang.Long cannot be cast to java.lang.Double][message: java.lang.Long cannot be cast to java.lang.Double] | 70963596948 |
| FileTransfer-8 |
Can any one help us.
regards,
DINESH SENTHIL
Hello, Dinesh Senthil.
The images you reference are not visible to me. Could you attach the actual log file for us to examine?
Thank you,
-- Craig A.
