Hi. I'm trying to find a template which add a configuration link (see attached image) to each instance of it. So my question... is there a Template that make this or do i have to create my custom template?. If that's so, how do i accomplish that?
Thank you for your time.
Hi Eddison,
if you want to create your custom Configuration Table I think you need to use a custom extension and create a custom template. I also have Configuration Tables in my Java extensions. Just create a new extension using the extension sdk, there you can define Configuration Tables for your needs.
For a Java Extension you would accomplish that via these annotations:
@ThingworxConfigurationTableDefinitions(tables = {
@ThingworxConfigurationTableDefinition(name = "ConfigTable", description = "", isMultiRow = false, ordinal = 0, dataShape = @ThingworxDataShapeDefinition(fields = {
@ThingworxFieldDefinition(name = "TableRow", description = "", baseType = "STRING", ordinal = 0, aspects = { }) })) })
Keijo
Hi Eddison,
Keijo
Thank You very much for the help, Keijo. I'm gonna work on this.
Keijo, Now i'm facing an issue, after installing the extension i check the configuration table and it shows perfectly, but if i click "Cancel Edit" the configuration link disappear, i attached two images related to this.
Also, sometimes when i reinstall the extension (with updated configuration) it takes the old one (Without the changes)
Thank You.
When you install a new version of your extension you have to consider two things:
After this it should take the new extension version. I believe the disappearance of the Configuration Table should be repaired as well.
Let me know if it works
Keijo
It didn't work at all. The configuration link doesn't disappear anymore, but i added a new configuration table and changed the version of the extension but the configuration section doesn't get updated when installing.
This is the Java code where I add the configuration table.
Did you restart your tomcat?
is it fully necessary?
As far as i know, yes. Otherwise it always will take the old extension version.
Well, i can't restart tomcat right now, as soon as i can i'll try it and tell you if it worked.. Thank you very much, Keijo.
