I recently created additional postgres Persistence Provider but after attaching and activating the persistence provider I am seeing duplicated tags in the composer.
I removed the persistence provider everything is normal now.
What will be the issue here, Is there is any solution for this duplication ?
Hi @sabharees
What procedure did you follow for setting up the 2nd database? Here is an article for your review to ensure you followed the correct procedure. If you still have issues, we probably need to open a case for this one.
--Sharon
Hi @slangley ,
I created DB & schema and added the persistence provider in thingworx. but I'm not sure why I am getting duplicated tags.
I'll be opening support ticket.
Sab.
