widget create
lc-3
2-Explorer
widget create
  Get value as undefined
  Why?
ttielebein
(To:lc-3)
Are yAxisRightName and yAxisLiftName showing as defined? I was thinking you may not be referencing the 'Data' property correctly since it is a sub-entry of 'Properties' in the given JSON, but if these other two are showing correctly, then this is not the issue for sure.
